The Zod
Some may remember this model I built over ten years ago. Maybe 2003. It is the DML M4A3E8,based upon the Italeri M4A3 hull. The turret is from either the M26 or M26A1 from DML. The 90 barrel is from Jordi Rubio. The markings are from a Verlinden set. There was only one Thunderbolt name.
I may add on a canvas cover for the mantlet. There are some areas that need weld beads. Not sure on how to add them over a painted area. Hoping to get a good weathering on them. I may end up getting a MIG olive drab filter set.
I think I will add a tow cable as well. It was built before I found out about Karaya copper tow cables. The cable that came with it was the usual Italeri plastic tow cable.
I applied tow coats of the grey green filter over a clear matte coat. I did not add any thinner this time.
