jknaus
Administrator
Okay I got this kit when it came out so I could build it for work. Borrowing Sauls boxtop art because mine is burried somewhere.
And here is a couple of days light work.
Body and box just resting on chassis right now. Painted the insides a light grey and will have to weather a bit. Chassis painted flat black. Read the review on PMM before you build this kit. Or be aware to make the front wheels steerable the instructions lead you astray. Do not glue the ball joints on the axle first. Instead sandwich them between the brake drum and the steering linkage and be careful when applying glue. Then carefully glue the assembly onto the axle. Its very tight and close, and it is fragile.
Have to sand some joints and work on the inside of the cab next. Then glue the body and box on. Very simple well thought out design going on here. This is a true joy to build. The hard part will be the cam. If I cant find some good pics of the Libyan markings I need I may have to choose another country. Just have to find a god pic.
