Panzer IV Ausf. F2 diorama finished ! 25/04/12
Hello guys,
I've started to build a diorama for my last model. I've first prepapare the wood base with high density polystyrene, Styrodur, and put the frame with a sheet of balsa wood....
Now I will proceed to paint the frame with black color...
Stay tuned !! Updates coming next..
Cheers :)
Massimo
Re: Panzer IV Ausf. F2 diorama
OOOOOooooo....
you dio guys are really inspiring me to sit down and do one. These SBS are really helpful. Thanks! :popcorn
Many thanks guy ! ;)
A little update... I will make the ground: I found a product, called "Modelform", from Amati that seems a sort of chalk; it can be mixed with water, acrilic colors (in this case sand color), rocks, stones, sand and a few drops of with glue. Once obtained, the compound is coated on the surface with a spatula.
Now I'm going to work on it !!
Cheers
Massimo
Re: Panzer IV Ausf. F2 diorama updated 23/03/2012
Looking forward to this build Massimo (y) :popcorn
All the best!
Dusan.
Re: Panzer IV Ausf. F2 diorama updated 07/04/2012
Hello,
the groundwork is made !! :v The next step is dark wash and dry brush on it.
Updates coming next...
Cheers
Massimo
That was FAST! Nice work, Massimo, it will make a fine setting for your panzer! :drinks
That looks cool. Nicely done sbs and thhe results look very good (y) (y) (y)
Many thanks Mike and James..
In this step I painted the base further, but unfortunately Reeves acrylic paint leave a glossy finish and I hade to spray some coats of matt clear.
Stay tuned, another update will follows soon.
Cheers :cheer:
Massimo
Re: Panzer IV Ausf. F2 diorama updated 09/04/2012
Hi all,
now this is the groundwork after the wash to darken it with brown Van Dyck and black mixed togheter....
The next step: drybrush with light tones.
Cheers :cheer:
Massimo
Hello Massimo, Great progress on your base (y) (y) (y) Looking forward to more updates!!
Randy
Many thanks Randy !
Another update: drybush with light tones. I also started to put some vegetations on the groundwork.
I hope you like it and thanks for looking.
Cheers :cheer:
Massimo
Hi all,
finally I finished this one, a little diorama for me as I'm use !
Figures were completed some years ago and this was the right time to place them on a groundwork !! :v
Any comments and suggestions will be much appreciated as usual and thanks for looking.
And now ahead with another project !
Cheers
Massimo
Hi all,
Cheers
Massimo
I missed this Massimo, looks good! Thanks for sharing with us. :mpup
(y)
