Jeeves
This one might pertain more to James since I know he has a couple under his belt and maybe has run into this issue! I lined things up as best as I could by eye and thought it was all good-- until I went to put on the top and bottom covers. From what I can see- things seem to be lined up ok-- but I am obviously hitting the issue with the frame being too wide for the top cover here--
And although I was sure the radiator and front cover were aligned ok-- with the plug that goes into the front of the engine- as one can see from this pic- where this bottom cover is supposed to be, I have a bit of a gap...
Have you come across these issues James (or others?) or am I the only lucky one??
![001~62.jpg](https://www.modelersalliance.com/gallery/albums/userpics/10783/001~62.jpg)
![002~57.jpg](https://www.modelersalliance.com/gallery/albums/userpics/10783/002~57.jpg)
