Tankbuilder
I've been looking at my Revell 1/28 scale SPAD WW1 aircraft kit. The wings are one piece each which means they are pretty thick and thus highly resisatant to warpage. Unfortunately Revell for some strange reason gave the upper winga bit of dihedral whereas the SPAD had perfectly straight upper wing. This kit dihedral is extremely noticeable, 1/4" or 5mm from wing center to wing tip, and needs to be removed.
What's the best way to straighten this top wing? Would a hair dryer be a better method than say really hot water? How would any of you do this?
Thanks and cheers from Peter
