Soooo, I finally got a chance to work on the MH-60M tonight. Man, it's been a long time since I worked on it and it took me a few minutes to get reoriented with my bench and model.
Being a former crew chief, and like Ramon, we sat beside the broom closets as they were called in the hawk, so I decided to tackle the bulbous top of the soundproofing and change it to more resemble the real panel.
Out came the #11 x-acto saw blade, sanding sticks and my handy dandy Dremel tool. After 2 1/2 hours of grinding, sanding, and grinding again, I finally came up with a close enough semblance of the SP broom closet.
As you can see here, the tops of the broom closets are higher up the crew chief window frame and they are in a semi circle shape.
All
I have to do is clean up where I had to use perfect putty and the right side will be done.
All for now until next time. Happy New Year Guys!!!
Tim
