Fokker DVII (OAW) in 1/48th scale by Eduard.
centaur567
This kit was sent to me from a WWI modeler and an on line friend, David Lee, who lived in Newcastle, UK. It is going to have the markings of an unknown pilot from Hesse, Germany, which is where my great grand father came from. This is probably my third D VII build. One I still have and it was by Rodan and is posted above. It had a fairly detailed engine and an option for open panels which I did. Plus a spare engine which will be built as a separate model and a fuselage as well. Gary S.
This morning, while working on both engined, I realised that I have enough parts left over from this kit and other kits to make another fuselage.
When I was building the D VIII model, I wonder why Fokker didn't build a low wing mono plane.
Now with all of these left over parts and scratch building the rest, I'm going to also build a D WF?. Gary S.
The wings are being made from layers of balsa wood. A basic pattern was made from the D VIII wing with a little increase in span. I also made sure that the span was longer than the D VII span. Then the basic shape was cut out with a xacto knife and the sanded to shape. It's going to need several coats of paint to see the real shape. It still needs the center of the wing to properly fit the fuselage.Gary S.
Noticed a little left-wing warpage that I'm trying correct. The left wing was soaked in hot water and then clamped. The wings were given a little bit of dihedral yesterday. Gary S.
I don't know what an earpage is but loving what you're doing here Gary. I could never get two sides look identical.
