Revell '65 Mustang Fastback
I've done quite few model favors for club members. Largely these seem to go un or underappreciated.
THAT, I do not understand! Hell, I didn't mention the favors as I know how you feel about the 'master' being a reworked kit part and I respect that. You saw that I not only loved by Cap-O-Matic (sorry if I get the name wrong) are not only utilized almost daily, I even personalized them!
So, starting on the engine while things dry. I cut off the oil filter and filled the hile with 3mm syrene tube.
The printed oil filter is more crisp
These are the parts I made. The fuel pump is not included as a kit part.
Back then, to me anyway, the Ford's were so much easier to work on than Chevys. I could could just reach over the hood to change the oil filter because it was located at the front of the engine. Changing a starter on a Chevy 283 was a nightmare. So is that a small block 289? Gary S.
Yessir, 289. My favorite!
Ok, I got the door hinges on. I "thing" I have then in the right place but will know more when I try to fit the doors.
Next up in my random order of assembly is the make the oil filler tube and cap. I fit a 3mm styrene rod in my Dremel tool and using a small chisel I shaped it into a cap. I had to whittle the rod down to 1.5mm to fit the hole I drilled in the valve cover.
It fits and looks good. The valve cover will be gold. The cap in my reference is black so I need to choose between that or chrome. I am leaning chrome to contrast with the black engine body.
Little more progress. The coolant hoses were molded but unusable on the waterpump so I cut them off and drilled with a 1mm bit. I used 1mm brass tube and a matching .5mm rod to make something I can use.
Nest up in random order I wanted to make the drain plug on the oil pan more correcter so I cut off the incorrect plug then cemented a 1mm thick square piece of styrene card. Once dry I shaped it with a chisel.
I have a new product. Tiny hex bolts in various sizes. I used the .85mm bolt. I won't glue it in unti after painting it chrome. Also, I want to work on the piece I added a little more.
Thanks for looking in!
@Greg Kimsey , @Sharkmouth
Something I found while working on the current howitzer build is that the various super small bolt and nut sets with the 1.0mm and smaller don't stay in stock long. I was able to get the larger sets fairly easy. Just a couple three weeks ago I found the Meng Small set available at Sprue Bros or Squadron. I bought 3 sets and have already used the small nuts on one side of one.
Ok, I got the door hinges on. I "thing" I have then in the right place but will know more when I try to fit the doors.View attachment 195571
Next up in my random order of assembly is the make the oil filler tube and cap. I fit a 3mm styrene rod in my Dremel tool and using a small chisel I shaped it into a cap. I had to whittle the rod down to 1.5mm to fit the hole I drilled in the valve cover.View attachment 195572View attachment 195573View attachment 195574
Funny, I seem to remember that Ford engines were painted blue. Gary S.
Ok, progress for today. Replacing the molded trans linkage (now removed) with metal. Using 1.5x.4mm brass strip (really wish I could get nickel!) I made tiny linkage bars. I used 1mmOD x .5mmID tube drilled out to .6mm to make spacers. The bolt is 1mm brass hex bolt. The linkage will be .5mm brass rod, but that is for later; my hands are cramping (and I have an aquarium to help break down). I will show a picture of what I am trying to do.
Ok, this was easily one of the most frustrating thing I have ever attempted. Not a joke or exaggeration. I have spent a lot of time on the floor with my flashlight. There were 45 bolt heads in 1mm and I needed 4 total. I have 32 left now.
I took this photo after my first fitting. I ended up replacing the tiny section of brass rod. I redrilled the holes in the transmission to 1mm and ran the rod completely through to the other side to make the situation more secure. I had to redrill the .5mm holes in the rod out numerous times. The drill bit was in my dremel and when I dropped the flexishaft it drilled into my thigh a little LOL. No serious harm done.
You can see the unused brackets in the background. I had the genius idea if using PE edging since it is thinner. I got 2 holes drilled. Each hole took 5 minutes and the drill bit was unusable afterward so I swicked back to brass and a new bit.
So here is the final answer some 5 hours later. It is not 100% accurate by any stretch but it is done and I like it. They DO move. Only the bolt shaft is glued. The bars took a lot of trial and error; mostly error. I finally landed on this relatively close confuguration.
Word to the wise; superglue debonder will also melt your cutting mat!
My friend, you are not a Club member. I did not mean to include you in my remark. You have always been a good bloke to me.
