Using AI to design and test dio ideas and composition
JSteinman
So I have been experimenting with using Chatgpt as an aid in designing dios and vigenttes. I use it to test different layouts and compostion to make sure my story is clear. I also use it for color mix recipes to get exactly what I want from what I have on hand. Sometimes it goes smoothly, and other times its like pulling teeth from chickens. Below are some samples of what i consider finals that I can base the dio upon. If you like where the Ponyri dio with the Stupa is going, that was the first one I used AI as a design aid.
And some title plate art.
So how do you get that started, just typing what you want or do you post a picture of a model and tell it to put it in a scene you describe?
So yes to all of thr above. Many times I start with an idea and a vehicle, often a real image, or sometime a historical event.
The top one, Ghosts of Napoleans started with a basic idea of the furthest the Germans made it to moscow. The BA-6 was just going to be poised over a snow bank with the sign. I thr. Instructed it to add some captured Germans and a guard with the BA in over watch. I have some such figures from Stalingrad. I then added the buried field kitchen to add abandoned equipment. And the house and fence to add Blocking and leading lines. This one went fast, others like thr soviets in thr pipe took much more and the bottom one took days off f iterations.
