Thanks Bob.Excellent work Tim!![]()
Yep. You can't have the "Baron" without "Dick the Bruiser"Looks good,a really great kit,I did the same thing,after I built the Tiger,I had to do a companion Sherman.
Still have things to finish up on it. I figure a couple weeks before primer.That's so cool, now the painting starts?
Be aware the MP-48 antenna base used a multi section color coded antenna that would be prominent at this scale.The crap I get myself into...
The seam lines on the antenna mount was just to much to remove from the spring, so I cut it off and made one from wire.
The 9ft whip antenna is from stretched sprue. View attachment 191742View attachment 191743View attachment 191744
I found this out yesterday. It makes sense, since it's so long. Thanks for the reference pics!Be aware the MP-48 antenna base used a multi section color coded antenna that would be prominent at this scale.
View attachment 191750View attachment 191751View attachment 191752
The sections are about 39.5" each so you would use sections MS 49, 50 and 51 which would be light blue at the base then red followed by yellow ending in green.
If I don't use an Adlers nest antenna, I just use alluminium tape on brass rod.I found this out yesterday. It makes sense, since it's so long. Thanks for the reference pics!
I'll be re-doing mine.
