1/16th scale sFH 18 Howitzer
I have a set of the diamond hones that Saúl posted but use them for dealing with metal parts. The 1200 works really good for removing nibs on photo etch parts. It even works on the steel PE parts. Then I have a set of credit card sized diamond hone cards. 400, 600, and 1200 grit. As I have some carbide cutters and fine jewelers engraving tools I also have the big 3" x 8" diamond plates 600, 1200, 2200, and 3000 grit for sharpening gravers and lathe cutters. Sharpen then polish them and they cut almost without pressure.
Right now, I am building an extension to mount on my lathe so I can put the LONG barrel in the lathe and make it round.
Here is the layout drawing. I have one more part to design, and some of the parts are already partially made. Since it is a line drawing, I could make it huge and the file size is still within the site's limit. If you really want to see the parts, download it.
Edit: (Sunday 04-19-26) updated the drawing, added the last part. changed the color on one part so it can be seen against the yellow background.
Now to get to work making and finishing all the parts. Hopefully I will finish this today.
LOL! Some of you guys know me and my fancy jigs. Only started this early Saturday afternoon. The design has been going through my mind for a couple of days. Designing this stuff is getting easier, and this should work fairly well.
Coming from a life long eyeballer (me)...this is impressive!
Yeah, I guess I have been a toolmaker and such as long as I can remember. I have a 1/9th scale Kubelwagen that I started back in the 80's. I managed to get the engine done correctly with the right details even though the kit was obviously based on a Kubel that had been pieced together with modern parts (front suspension, and engine) What made me put it aside is that the sheet metal of the body that can be seen on the inside did not have the ribs molded in relief on the inside as they should have been. To get them right I was going to need some way to mill them so they would be straight and an even depth. Started making a mill table from brass tubing that could bolt onto my Dremel drill press. One thing and another it got set aside and never done. At some point I really need to finish that beastie.
Have been busy today drilling holes milling parts to size. While I could do things as a production line, I do take short cuts to make sure holes align by drilling the hole in the top part, then positioning the lower part and drilling a start hole into it through the upper part. If there is any miss positioning of the hole even slightly, the mating hole will line up just fine.
Couldn't you just break that barrel down to shorter lengths ? off set the tail stock for the taper ?
Cutting it apart into shorter sections would introduce all kinds of other problems that I won't go in to. I have the new jig about halfway done, and it is going to work just fine for this stuff. In addition it might also help with some other issues I have with on going short jobs from work. We will see about those once I get it all built. So far it is coming along well with fairly tight tolerances and should give me some options to work on larger parts.
Here is a quick update on the progress of the lathe extension. It is about 70% done at this point with 4 small parts for the main unit and then I need to make 2 parts for the lengthened steady rest for gravers/ cutters. You can now see what I was envisioning in my head. This won't work for any heavy cutting, but then the lathe itself isn't up for big or heavy stuff so this is a win. There were 16 inch long lathe beds made, but they are quite expensive even for used ones in poor condition so this is a good modification that will get used a bit once it is done.
The T blocks will be the next on the list followed by the pointer/cup. Stay tuned.
Nope, the watchmaker's lathe is just not up to doing something like that. It can do large plastic parts but the metal parts take a LOT more horsepower.
Thing is a metal barrel of the size that this gun is would weigh quite a bit. The plastic one will work just fine.
With all of this excellent work you could now just turn a new, seam free, metal barrel.
Here is a better answer. This is a watchmaker lathe. Mainly designed for very small parts up to small clocks. I can do larger plastic parts, but have to be very careful and even then if I do more than just shave off a little material it can totally stall the lathe, so no metal gun barrels. I could turn say a 50 cal barrel or something along that size, but it is easier and cheaper to just buy some really nice barrels from Master Model.
Thank you for the clarification.
Here is a quick update, then back to cleaning up the mess. Any time I do machining, I end up with a bunch of aluminum trash and what almost amounts to shiny glitter. If not careful it ends up all over the house.
Once the mess is cleaned up I will have to get on to other things. Busy, busy.
Time for another quick update. With some primer applied to the barrel it turned out nice and round. :dude:
Thus it was time for some more assembly into bigger parts, etc.
With the barrel done and some primer having been applied, I decided to do a quick "fit" together.
It is QUITE a bit BIGGER than the Pak40 and what is here isn't even all of it when put together.
Another viewpoint. The Pak40 is closer so it doesn't look as small as it is. The above photo gives a true size comparison.
Very good Paul, you and i are of similar mind in that if a kit had no issues.....we would have to make some :) , i suspect when you have finished this build you will look back on the barrel as being the most fun bit .
Well have been painting primer, touching up details, doing mods that don't break the bank, and discovering that the guys that designed this kit had their heads buried up their hind quarters.
I get that sometimes things are hard to figure out, but golly gee whiz with a side pat of :poop: !!!!
This model cannot be built in transport mode. None of the things that NEED TO LINE UP actually DON'T LINE UP!! If it is build in full spread firing position, it isn't an issue, but for transport it is screwed up.
Here are the offenses!
It would not have been all that hard to do a little photo study and make the mold for these items to be in the RIGHT EFFIN PLACE! Lastly, in comparing the photos of the carriage trails, only about 1/2 to 2/3rds of the rivets are actually there. No, I am not going to bother adding more as this is just going to be assembled and painted up for now. I did mod the very ends of the trails so the "sort of" look like the photos. These could have been done correctly as well instead of the shit job they did do.
So this Merit kit gets 20 DEmerits. and it isn't even finished yet.
I feel for you Paul. we had a series over here on TV about the day to day work of Airfix and before they put a model on the market they had a guy, not related to the company at all, who would build their models in prototype form and report back, he is also the guy that builds for the photo shoots and publicity as well. How difficult is that for a company before production ?
My guess is that they discovered too late these FUBARs and that is why the model for the box art is displayed in firing mode. What gets me is that they have all the little details there, just not in quite the right place. Unlike the Das Werk Pak 40 which was missing a bunch of "IMPORTANT" stuff and the shield FUBAR, this was just plain lazy stupid.
I feel ya.
My wife tells me to calm down it's just a toy...🤨🤐
The zipper fits Tim.
Yeah, do I have the skills to fix it all, for sure! Do I want to bother with it, nope. As I don't have any kind of tow vehicle for it, not worth the effort. I would rather build it in firing mode and then turn some masters for several shells and cartridges, then make a mold and do some castings.
As the kit didn't come with any ordinance, at least I have some info to make masters for my own. The only thing better would be clearer scans/photos that show the dimensions a bit more clearly. @Sharkmouth Saúl is the only person I know that might have that kind of info.
