Bob's Work Bench
I bought a 5000K light at Harbor Freight to light up my work area a couple of years ago and love the amount of light it puts out. It is mounted under that giant shelf I made to go over my work area and I had to put some paper across the front to shade my eyes when elsewhere in the room.
I need something under the desk, need to find some bolt on under table drawer. I got use to that. I think I'm going to dive in and start placing stuff where it lands. Yep, first up, (forget about the cubby for a while) is finishing up the Lee.
I know the varnished wood looks nice but i would be looking to cover that with something ? even something easily removable and replaced like a sheet of Formica so when the inevitable paint pot gets knocked over or the super glue bottle falls over and leaks out all night kits and easy clean up.
Paddy I had a drawing table matt for the old setup, I have thought of this and I'm looking around now.
I have glass over some of those rubber shelf mats available at Home Depot and Lowe's on my workbench and paint booth areas. I draw and mark notes on them with sharpies and such. If I am hand painting a small item and need a drop of paint to use or mix for a minute, I just put it directly on the glass. Super glue drips and spots are the biggest offenders.
Fairly often, I move things out of the way, scrape off the CA and paint blobs then spray it with glass cleaner and wipe it clean.
Found a deal on this
They cut it down to 60" and I took the scrap. I'll crank up the heat gun and see if I can bevel the ends around the corners of my desk.
I'm sure someone will have issue with this someway or another but we'll press on.
Heat gun didn't budge this, but then again it's 60" that needs to wrap and I don't think I have the skills. May end up getting the drawing table matt. I can use the plexyglass stuff for other things..maybe.
Hey Bob, this rubberized shelf liner (like what is used in tool boxes) is what I use under my pieces of glass. This photo is from Lowe's and it is $19 for a big roll. Set your acrylic sheet on it and it absolutely will NOT move unless you pick it up and move it. It also adds another layer to help protect the surface underneath. It comes in Black, White, and Beige (as shown here) I find the Beige color is easier on the eyes.
