Do it again Rosie
While I wish I had the gumption to rebuild the tail wheel itself, I'm ok with this so far.
JUST found this photo.
The mount look more like a leaf spring. I might have something for that also.
Sorry i am just catching up here Bob. That undersize piece of clear !!!! why do they do that ? they could give you an A4 sheet and it wouldn't cost as much as them trying to cut up a piece to size. On my last car build Italeri give you a piece of 7mm tubing to make some hoses. its 30mm long and if you add up the dimension in the instructions the four pieces required add up to 35mm ? this plastic tube is throw away price. I just bought 6 sheets of A4 , 0.4mm clear for exactly the reason you needed it. The postage was more than the sheet :) (moan over)
Love the tail wheel I probably have the springs you need as well, 5mm long from MFH labelled as exhaust springs for holding silencer to pipes.
Thank's Paddy, I couldn't find the clear sheets at the Hobbylobby but I did find clear sticker, stuck the frame to it then a couple of coats of clear deactivated the sticky glue. It's not up to exacting standards but works for me.
I'm going to add another run of brass to simulate that leaf spring action. I got the chain and spring work already mapped out.
I also can supply defunct watch mainsprings. They can be brittle, but heat them real good (till they start to glow) over a candle flame and they will bend quite well and actually be springy. They are some steel alloy and can be quite strong for what they are.
Just PM me if you want some.
The tiniest springs I have come across are the filament in the old incandescent bulbs.
Yes! Every filament bulb I have that goes out gets the filament harvested. I found the easiest way to open the bulb is with my coarse bench grinding wheel. I touch the bulb to the corner edge of the wheel just above the metal end. It grinds through quickly and causes the glass around the metal base to crack loose. No pop, no shards on the outside. There are a few that are sucked inside the bulb, but not an issue. I then pull out the center part with filament, remove the wires, and store them in a small box and pitch the bulb.
I remember chuckw used a filament on one of his builds years ago before he got all angry. That is where I learned the trick.
I used a filament for a spring on my 251 engine.
I think you would be lucky to find a filament bulb over here now, most were banned years ago. I dont know but i would guess a new filament would be better than a used one that had done thousands of heat cycles. ? i think my approach would be to wind my own to fit given most springs on models are just show and dont need to be spring steel although i appreciate if you have a bulb to hand its a lot easier..
