White_Wolf
Thanks Mark, much appreciated.Oh this is so magnificent to watch! Way to go!
that video sure put me in my place too! Wow, what amazing talent he has!
Thanks Saul,Wow!
Also, thanks for not using thumbnails. Pictures are perfectly sized!![]()
Thanks Paul - I was feeling adventurous, trying new things. Go big or go home kind of a thing, may not be everyone's cup of tea.I am still impressed with the fact you are doing a sea on this large of a model. Sometimes the best way to get through it is a little bit at a time and ponder the next step in between.
I know what you mean in that I have several large aircraft and the plans for them call for boards that are going to be at least 26 x 26 inches. The fun part will be coming up with some kind of display case to hold them. Will probably have to build that as well.Thanks Paul - I was feeling adventurous, trying new things. Go big or go home kind of a thing, may not be everyone's cup of tea.
With you on that one - I went for a glass display cabinet from IKEA - I have an A10 sitting on a square mirror-like tile (IKEA again). Cabinet is all glass (except for top and bottom) including the three shelves.I know what you mean in that I have several large aircraft and the plans for them call for boards that are going to be at least 26 x 26 inches. The fun part will be coming up with some kind of display case to hold them. Will probably have to build that as well.
I did not imagine I could share anything you hadn't tried on your extraordinary Bismarck. I only know a few tricks.The frame is hovering above ground, sort of a gravitational mambo-jumbo lingo thing here
The silicone I am using leaves no trapped bubbles, which is great - the previous one I tried was impossible to use - a TON of bubbles . Also using methylated spirits to smooth it and prevent it from sticking to my fingers when laying it down.
Once the cotton is stuck to the base (using a bit of silicone for that), I am using a bit of hairspray to make it stiff and give it a bit of a glossy / shiny look.
Laurence
