fledermaus
Great job so far Bob, its going to look so cool when finished
I'm humbled, thanks! I hope to be modeling again soon.Great job so far Bob, its going to look so cool when finished![]()
You're going to have to explain that one to me Mike.AMMO makes a thin and thick Plasticator that provides a base to prevent the soaking up you're talking about...might want to check that out Bob
I was thinking shadows actually.Would the sand be darker if someone drove over it? I believe you are overthinking your sandy tracks.
Right, I remember doing that now. Where are you suggesting I do that?Bob, it’s essentially diluted PVA glue. You could basically water down some Elmer’s and it will achieve the same thing.
Ah I should have use the PVA as a seal coat. Gotcha and noted. Yeah I got some corrections to make. Thanks for checking inI guess all over the sand to seal it so paints don’t soak into it.
I don’t know if I would now that it’s already happened, I’d probably just soldier on and complete it but maybe next time?
At the time I had the materials, but not the money for a paint booth. Also it is fairly large and can accommodate most 1/32 aircraft.Thanks Paul, it's based on some photos I had seen, there's some knock down I might do but the tracks stay.
I might just buy a paint booth, I'm not that industrious to build all that with the plexi and all the other materials.
clear acrylic base wood glue works perfectly to seal the base before the ground work or after before you start painting....been using it for 45 years without an issue -cheap too.AMMO makes a thin and thick Plasticator that provides a base to prevent the soaking up you're talking about...might want to check that out Bob
