Alright got back to this, have the body 90% cleaned up
What body?!!If they are to be crinkled and not in the closed (flush) position, is it noticeably large?When I test fit the parts to the body, they both were to big. You have to ride the horse to learn not to fall off. I'm going to need more brass
No need to throw in the towel. Use the car door opening to trace the form onto card stock from which you use as a templete to cut thicker sheet styrene to form the shim brass. The removed kit part helps get the curved shapes right and it will fit.I want to try a couple times more before I throw in the towel.
A double or triple layer of aluminum foil laminated together with spray adhesive might be easier to work than the brass and would still be crinkleable. Is that a word? I'd also suggest popping the door open a bit, that would help conceal the differences in size.
Rock on!
