Haven't seen your name in a long long time. Welcome back!Wish we could get that Chopper in the USA. I bought a "Chopper II" but I did not like it, to much wobble.
Some nice items there Chris! I have the HK B-25 kit as well, you might try and find a pair of engines from HPH to use on it as the engines in the kit are horribly incorrect. Also I had a bad experience with the Ju-88 G-Factor landing gear. They were about 15% undersized (in all dimensions) and total garbage. I ended up modding the kit gear and ended up with a much better result anyway. After that experience I now pass on the aftermarket gear except in rare cases. I will buy Eduard bronze landing gear and Zouki Mura landing gear (which I think are made by Eduard for them)Order came in with the bits I need for my MA10 build...along with a couple extras.
Yeah I'm quite impressed with this one as well. Just need to start one. Looking forward to your build for hints and tipsI read about that in Vladimir Sulc's editorial in the May Eduard Info. He said:
The Bf 108 in 1:32nd scale. This is a ProfiPACK kit. As you are probably well aware, this is a kit who’s development was undertaken by another company, and was never finalized before the moulds were put up for sale. We bought those moulds and are releasing the kit under our own label. We also purchased the boxart for this item. This kit, under the original label and with the original boxart, was introduced and partially advertised before. We are planning to release this kit as per our established practices, meaning that it will first be released as a ProfiPACK kit, then as a Weekend Edition kit, and finally as one, or perhaps more, Limited Edition special boxings. The first, being released this month, is the ProfiPACK version. It follows the standard norm established for the ProfiPACK line, meaning it includes photoetching, masks, and five decal options. The kit also includes a resin wood propeller option. The reason that this is rendered in resin is that a wooden prop option was not part of the plastic components, but is relevant to many marking options.
I was very impressed with how the parts all look in the kit! The gigantic greenhouse canopy is very clear and almost perfect with minimal distortion. There are also canopy parts, so if you choose to open the side doors it can be built that way as well. I think it kind of ruins the look though and since the clear is so nice, I will be building mine closed.
