HI friends, here with a new update on Dora, the work on the barrel is finished. Some changes were made and here it is.To start there is a big part like a sleeve that connects to the breech block that is missing on the kit, to make it I found a PVC drain piece that had the right diameter to make the missing part.
Here you can see the missing part
This is the PVC drain part used
After removing the screw bases and sanding it smooth it looks like this
A small 1.5mm styrene strip is used to make it fit tight on the barrel
After a little sanding and a coat of primer it is dry tested on the barrel
It works perfectly, the gap is supposed to be there as seen on the reference picture
Here the breech block is added to check that all fits with no problem
Now the recuperators’ bases are modified to fit over the PVC plastic sleeve
The lower part is split in half and cut away and sanded down till it fits over the PVC sleeve
A comparison of the original part on top and the modified part bellow
The recuperators main body is installed to check the fit of the modified parts
The lower recuperators main body is also installed and all the parts glued in place, I used a rubber band to keep all in place after gluing all.
Here it is finished and now looks like the original gun part
Now the lifting points on the barrel are also modified to look closer to the original ones
Here is the original kit part
And the reference picture
1.35mm Styrene sheet is used to make the bigger lifting ears
This are sanded to shape and the new hole drilled out
The new lifting ears are glued to the kits bases
Now when the lift ears are glued in place but the position of the ring is offset, the
lifting ear should be straight
The ring has two pegs to align it to the barrel, so I just cut the pins and placed the ring in the correct position
Now it is in the correct position
Next the recuperators cylinders are modified, the end tube is removed and a thinner one glued in place, a verlinden nut is glued to the end of the tube
Comparison of the cylinders after the mod
The smaller recuperator shape is different from the original on the Dora photos so I removed the tube from the base
After removing the tube, the base is sanded smooth
A new tube in the correct shape is made with 3d printing
The new tubes ready to install
Two new rings for the base of the recuperator are made with styrene sheet
Test fit of the rings
To simulate the screws I used 1mm diameter rod
After marking the positions the bolts are glued in place
Here the recuperators are installed to the barrel base
To finish the work on the barrel the rifling is installed, acrylic putty
 is used to fill the gap created when the barrel was shortened
And a couple of reference photos
Slowly inching to the painting stage of the gun, the last modifications
to the loading platform, carts and elevators is in almost finished and
work on the base about to begin
Thanks for following!
Abdin
