Were all 3 engines the same?
and all that it say is that they changed #2 to four bladed during production and retrofitted older birds .
Late variants of the PB2Y Coronado were equipped with four bladed props on the inboard engines and three bladed on the outboards. While researching this I found several theories but the most compelling was that the Navy wanted reversible props on the engines to allow the aircraft to back out of jetties and improve water maneuverability and the only available reversible pitch props at the time was Curtis four bladed units.
Probably not the reason for the one on the Bv 138, no doubt lost in time but I'll see if I have anything in my references.
Well, other theories for the ones on the Coronado were more clearance between the prop and fuselage (since the engines all had the same HP rating the four bladed units were smaller in diameter to match the load of the three bladed units) and since many of the Coronados were used as VIP transports it was also claimed the four bladed units would make for a quieter cabin. Personally I wouldn't think it would make that much difference. The first theory sounds the most logical to me.
I think you nailed it Christian!
That makes perfect sense!
Hope you didn't destroy your 138 to prove that point!!
:pinch:
Maybe someday
