Tankbuilder
Okay; thanks to the current Frankenhawk build by fightnjoe I decided to start working again on my old 1/48 scale CF-100 Mk IV 'Canuck' (akaa 'The Clunk') that has been sitting in the drawer for a number of years now. Here are a number of images as it appeard then and now before I do any more work on it.
I bought two of the 1/48 scale Hobbycraft kits of this bird because I got them at a very low price and I wanted to open up some panels and do some weird things like open up the dive brakes on the top and bottom of the wings. I also wanted to make the two piece rudder movable and try making the canopy moveable and the landing gear retractable. By using two kits, one for donor parts, I was able to cut the openings or the parts off the actual model kit undersize and cut the donor parts off oversize. Careful filing and/or sanding then allows the parts to be mated closely with only a small gap between them rather than a larger one the thickness of a saw blade.
I kind of got carried away and decided to build one Orenda engine and to detail the radar and the radar equipment bay in the nose.
I'm also building a detachable belly gun pack. This pack had eight .50 caliber machine guns in it and by an immense stroke of luck I discovered that 1/35 scale .30 caliber machine guns are extremely close to 1/48 scale .50 caliber machine guns. I had a number of sets of the Italeri Accessories Set that has two .30 caliber machine guns in them. I was able to scrounge the needed ammo feed belts from an old Monogram 1/48 scale Huey Hog kit.
The 1/35 scale Huey UH-1D Gunship kit donated the 7 rocket practice rocket pods for my Clunk. Other kits donated other wingtip mounted arnaments. Not all of these were mounted at the same time.
There's a lot to be done on this old bird yet and I really hope that it shapes up reasonably close to the vision I have for how it should look.
I'll be painting it in the Canadian NATO camouflage pattern.
Here are some images that I hope you'll enjoy.
Comments welcome.
Cheers
Exploded View of my CF-100 Mk IV model
View of the Main Wings and Weapons
View of the Fuselage, Belly Gun Pod Guns and Belts plus the start of the scratchbuilt Orenda Engine
View of the Canopy and the Radar Equipment Housing Area
View of the canopy opened by beind slid back on its scratchbuilt rails. The clear portion of the canopy is the kit piece filed and sanded so that it is much thinner and then polished again.
View of the Itaeri !/35 scale .30 cal guns being used as 1/48 scale .50 cal guns. Also the Monogram 1/48 scale Huey Hog gun belts and 1/35 scale .30 cal ammo boxes.
View of the started scratchbuilt Orenda Engine. Lots of work to do on it yet.
Front View showing the open canopy and the front of the Orenda engine.
Front View showing the scratchbuilt canopy rails on the canopy and the scratchbuilt guide channels on the fuselage. This canopy can be slid closed or opened.
Close up of the front of the canopy showing the I beam that was modified to an upside down T and cemented to the bottom of the canopy to be the rail.
Closeup of the opened canopy showing the canopy rail guides on the fuselage. These were made from two lengths of I beam modified to be upside down L shapes. Not the grey gap between the in the channels in which the canopy rail slides.
Thanks for looking. Thanks for any and all encouragement.
Comments welcome.
Cheers
 Watching close.
