Heat the cable up, that will take some of the spring out of it.
Thanks.Looking good.![]()
I've had luck putting on a good coat of Future before whitewashing. That way it rubs off easier and you don't damage the under color.
Future never was a wax, it's an acrylic floor finish. Still available from lots of local sources including Walmart under the Pledge label.
http://www.walmart.com/ip/Pledge-Floor-Care-27-fl-oz/15136693
A clear sealer that isn't based with what you're washing the white off with should be OK.
Not bad Chad![]()
