Tankbuilder
PT Boat Rebuild = 1/32 scale Lindberg Kit #2
Avast there mateys!
I have had this model for a long time. It is radio-controlled and over the years after many trips to the local pond it had suffered a fair bit of damage. I decided to refurbish it and this is where it's at now. This is not the same model as the In-Progress build I am doing in another thread.
It too is vastly modified from the original 1/32 scale Lindberg PT-109 kit.
The bridge area has been very heavily modified with lots of scratch-built parts added.
On the fore deck the hatches were moved to their proper locations and a small hatch for the anchor compartment was added on the extreme port-side fore deck.
The mesh in the bottom of the raft is a plastic mesh I often use for large-weave camouflage nettings. It was purchased at Wal-Mart.
The barely visible grating on the floor of the bridge area is a piece of fine-mesh plastic rug-hooking canvas. This canvas comes in various sizes of mesh and is perfect for gratings.
Here are a number of images of this other 1/32 scale Lindberg PT boat I am working on periodically as the mood strikes me.
Thanks for looking and comments are welcome.
This is the foredeck and shows the repositioned deck hatches plus the added small hatch for the anchor. Just in front (on the viewer's right) of the chart house is a platform for a mortar that was used to fire illuminating rounds..
You can also see the spray strips that I had to add to the hull because Lindberg doesn't include them.
The torpedo tubes are assembled the right way around and not according to the Lindberg instructions which has the assembly backwards. In this view you can see the scratch-built torpedo running out gear. The torpedo tubes were hand cranked outboard prior to the torpedoes being launched. I have made these torpedo tubes movable so I can have them with in the inboard stowed position or ready to be fired.
Forward starboard quarter view showing the spray strips on the hull near the water-line.
Starboard view showing from bow to stern, the torpedo tube, 4 scratch-built depth-charge racks and two 20mm Oerlikon gun ammo lockers for spare magazines. The depth-charges were used to discourage pursuing vessels and could break the back of a destroyer.
Aft starboard quarter showing the 20mm Oerlikon ammo lockers and the 20mmOerlikon gun pedestal.
Stern view showing rear hatch and six 20mm Oerlikon ammo lockers.
Aft Port quarter view showing the twin .50 caliber gun tubs, the rear torpedo tube turntable mount and the bridge area.
Port view showing the proper height of the antenna mount. The kit one is far too short.
Fwd Port quarter view showing the elegant lines of the hull.
Overhead Stern View showing locations of 20mm ammo lockers, depth-charge racks and aft Port .50 caliber gun tub.
Overhead Stern View showing locations of 20mm ammo lockers, depth-charge racks and aft Port .50 caliber gun tub. Note the two open lids on the starboard 20mm ammo lockers. These will be operable and will have tiny chains to hold the lids open.
PT Boat Rebuild 12 Overhead Bridge. This area is almost completely scratch-built. The cabin under the raft was heavily modified as the Lindberg cabin side parts had the wrong angles on the front and the bridge area was totally wrong and missing any details.
Note the different spacings of the rings on the torpedo tubes. The distance from the front of the tube to the first ring is less than the distance from the last ring to the end of the torpedo tube. This is what Lindberg has reversed in the instructions.
A closeup of the scratch-built bridge area and instrument panel. Note the hand-scribed deck planking.
The fore-deck showing the repositioned hatches and hand-scribed deck planking.
The fore-deck showing the added small hatch for the anchor.
The 40mm Bofors gun started life as a double gun mount on in ancient 1/32 scale Revell M-42 Duster kit. I cut the guns apart and used the receiver and barrel for a single Bofors gun.
Top view of the 40mm Bofors gun. A seat and a hand-crank need to be reattached to the starboard (viewer's left)side of the gun.
Rear view of the 40mm Bofors gun. The spent casing chute needs to be attached.
Closeup of the 40mm Bofors gun with parts to be added.
The twin .50 caliber guns are not Linberg's lumps of plastic. They are Italeri .50 caliber receivers with styrene rods used to represent the barrels. The mounts for these guns are entirely scratch-built and the ammo trays will be added later.
Top view of the scratch-built .50 caliber gun mount.
This is the reworked raft from the kit. In real life the raft was made from balsa. The mesh on the bottom of this raft is mesh from the fabric section of Wal-Mart. It is also good for camouflage netting if it is well washed.
There is much more to be done and I'll post more images as the work progresses.
Cheers and thanks from Peter
Avast there mateys!
