Wreaking Havoc 1: A-20B 41-3266(?) Outhouse Mouse with a Sharkmouth
Getting this out of the way for when the time comes...
My curiosity is piqued! When does the plastic begin to go together?
Since I am working on five, each shows where I am at with a common thread showing what was, or is being, done to all.
On the A-20B, this thread, I have almost completed the engine cowling covers and now feel confident to work on the nose after finding more images of the subject.
Sadly, some of the things I looked forward to, such as the additional four guns in the nose, or the rear firing nacelle guns, won't be performed in the sake of accuracy.
Not happening - circled rear firing guns:
They're not there on the subject :(
The four guns, seen on the A-20C, can't be used... look at the photo of the subject and see that the guns are mounted high, like the dual setup, not this one.
This MACR shows that it was possible to have four additional guns in the nose along with the rear firing guns:
Having received the resin casting kit, I need to decide if I should create the formation lights or wait until the fuselage is together.
So again, after the nacelles are completed, they need light riveting done, I will concentrate on the two additional guns in the nose.
I know they use to have "passing light" on cars, kind of a low beam, for when you met someone, not the overtake passing. I don't think I've ever heard the term in aircraft.
@moon puppy, ya made me look in some manuals!
Now I know it is a red lens. Passing lights on aircraft are based on the nautical world usage:
When seen on approach, you pass to the right of it, which will place you off the approaching aircraft's left wing. It is not kept on as it is a high intensity light. It is used in conjunction with the running lights (port/red and starboard/green) which indicate the wingtip. Formation lights were blue.
From the B-25 manual but they did print the light lenses in the color they appear. Passing light is red next to the port landing light:
That's what the positional lights were for. so you can see left right orientation of the A/C. I don't really get it but ok.
Ok, let's see if I get this straight.
Running lights help anyone understand the aircraft orientation as there is a white one on the tail, red on port and green on starboard. If you only see red and white, aircraft is yawing (turning on a horizontal plane) to port (left from the pilot's view). If you only see green and white, the aircraft is yawing starboard. If you only see red and green, the aircraft is headed towards you. If you or they are approaching quickly, the red passing light is turned on so you move (pass) to the right (where the red port running light is). Formation lights help you orient where the aircraft is and how far as the further, the lights seem closer together. The recognition lights (white on top and red/green/amber on the bottom) are used to signal to ground that your are a friendly based on the pattern. The white let's them know you're inverted. The bomb formation lights, different from the rear running light, has a white bulb which is on when the bomb bay doors open and a red one which signifies bomb release and has a 5 second delay to ensure all ordnance clears before another aircraft tries overtaking from below.Landing lights are to light up the runway when alighting (fancy word for landing) and the only one missing, used by the British, is the anti-collision beacon which seems like a strobe light but is not. It is a white bulb in a larger encasing which sometimes had a spinning reflector which gives the appearance of a lighthouse sweep.
How it is supposed to work:
Some illustrations. Note that on the jet, viewing from behind one doesn't see the red and green running lights as the formation lights behind it overtake their brightness. The A-20 with clear wingtips has this setup.
Control of the recognition lights (white on top, red/green/amber on the bottom):
Resin lenses in red/green/amber were not to be used for more than 30 seconds when on the ground as they would melt:
The upper one didn't seem to have this limitation.
On this Corsair schematic, one can see how the red/green running lights are mounted in a way that they're visible form the front but not the rear:
This was all inspired by the natical system in use. @Rhino probably knows more than I here!
Recognition lights ( lower aircraft ) . They were a code for ground troops to know what was flying over their position after dark to avoid friendly fire . The three light were used in a predetermined order . Code of the day .
Rear fuselage blue formation lamps. Note that the white item is a ceramic insulator for the antenna entry point:
Tail... note the British Havoc doesn't have them but does have the anti-collision beacon absent on US aircraft. Arrows - blue formation lights, Circled - starboard green light circled on US Havoc, anti-collision beacon on British Boston:
Let's look at images of the secondary aircraft controls located in the gunner's compartment. I'm trying to find a usable image from an A-20C (Havoc Mk. IIIa) manual.
A-20A Manual:
From A-20A Parts Catalog. Of interest is the stowage for the control column (A).
F-3 (Reconnaissance variant of A-20). The zippered curtain is access to the camera man's location if what is the rear bomb bay section. F-3 could revert back to their bomber roles as no equipment was removed, only added.
A-20B Manual.
A-20C interior... Still looking for manual image to see of the control stick is stowed or missing.
Seen before but worth repeating. A-20G-1 Manual (note the gun nose and the open rear gunner's area). Aileron controls don't reach the gunner's compartment, therefore the aircraft controls are no longer there. Rudder and elevator controls do run to the rear past the gunner's compartment so can't be used to prove the lack of a secondary set of aircraft controls.
For the longest, I thought that this was the rear gun position on all until the turret. The guns, whether single or dual, regardless of caliber, would be on a semi-circular skate rail similar to the pulpit in the halftracks of the time.
Single .30 Cal Browning on semi-circular rail:
Dual .30 Cal Brownings on a semi-circular rail:
Single .50 Cal Browning on semi-circular rail:
From the A-20B manual which I will be following, along with the image above:
Then, I saw this in the Crowood book but it only applies from the A-20G-1-DO to A-20G-15-DO... Note the transverse straight rail.
Well, I saw the oxygen bottle at the bottom of this image...
So, I bought some nice oxygen bottles for both of my subjects with open gunner's compartments, since they should be visible from the top... it turns out that they're too large to use!
Below, the left side part is the start by removing all the flat molded flight controls and then the oxygen bottle. Right side shows the stock kit part:
It turns out that the Resin2Detail part is the Type G-1 Shatterproof Oxygen bottles (bottom of photograph) while I need the non-shatterproof Type F-1 which is a bit smaller. I considered getting the 72nd scale bottles as they would be 67% smaller but they still have the straps molded on which makes them 'shatterproof' while the kit correctly had them plain.
The next questions was, how many do I need?
One as in the bottom here?
Two as seen here?
Or three as in the Soviet manual?
Well, it seems I need three, according to the A-20B manual:
The saga continues as I try to make the oxygen gas cylinders and then somehow place them!...
Luckily, I only need three as the A-20G series, all of them, converted to eight oxygen gas cylinders stowed vertically in the upper bomb bay away from view.
