MM2CVS9
Well, I've decided to make a couple changes. I never liked the bench style seats and the "floor boards" . These are as the kit instructions showed and were ok with the client.
The cockpit is somewhat out of perspective as the bottom of the hull up to the design waterline was ground off so it would look as if it were in the water on his diorama thingy. So, the floorboards are too elevated (can't do anything about that), the seats look too close to the floorboards (same problem), and the bottom part of the centerboard trunk is gone.
Before I get too much more rigging in the way, I'm gonna try to "pop" the seats and floorboards off and make new ones that should look like 1 X 4 or 1 X 6's. Maybe even 1 X 2 or 3 for the duckboards. They might be tough to get off as they were glued directly to the "raised" replacement bottom which is now flat. Will still look better if I can do it. Also, I don't like the mahogany supplied as the grain is very coarse. I'll try basswood or something stained mahogany color for a tighter grain look. The pivot pin for the centerboard trunk won't show because it's below the bottom, but a pin used to lock the centerboard in the raised position will be there.
Wish me luck getting the old parts off without damaging anything else.
EJ
EJ
