Soviet ASU-57 assault gun
Off to the races! My wife is gone on conference this week so I'm watching the two girls and one of them has a fever! Needless to say, not much progress but I wanted to start into this right away!
SInce the only other armor kit I have to compare this to is the Tamiya type 1, it is clearly no Tamiya kit! But, not that bad on first sight. They were very considerate to provide a part/sprue map and little tabs beside each part on the sprues but failed to attach numbers to either of these so it is going to be a guessing game which parts to use! The parts are listed on the jumbled instructions though!
I did get the lower hull together. These 4 pieces actually went together very nicely, just had to really watch which way part 40 went in as that wasn't clear in the instructions.
40 had to be trimmed as well where indicated, just a little shave of the knife.
I then discovered why I read that there were fit issues with the hull. the upper hull has many! First one being this area by the drive gears. It needs some major trimming
Then, one needs to trim the forward parts of the sponsons (?) I think that is what these are called) on the lower hull.
followed by the back areas on the upper hull
That should get you to a point where the upper hull almost nicely fits on the lower hull. I'll need to fill in these areas more once I glue the upper hull to the lower, and remove the AER Moldova markings!!
in test fitting the rear plate I found out that the previous rear areas mentioned need more trimming for the rear plate to line up nicely with the rest of the body.
Then lastly, I just tested the gun in place. Have to figure out which pieces are used to build that up!
