Here is my latest progress done at Hobby Day and a few days before and after. I was very happy with how much I got done.
I'll start with my aircraft; or in this case, helicopters.
I finished painting the interior for the HUP-2, so once I get the windows in the fuselage, I'll be able to close this little bird up:
I also got the interior painted on the Huey Hog. This one will be able to be closed up after I apply the instrument panel decals and then install the windows as well:
Now here is the work I did on the Gotha I bought from my friend. He had already assembled the booms and the wings, so I started with the cockpit... such as it is:
This model gives the option of making this plane a glider or a powered transport aircraft. I decided that since I haven't got this in powered form yet, I'll build it with engines:
As those were drying, I then added the engine nacelle parts to the wings that will hold those engines and the booms:
That's as far as I got on that. After all that I moved on to my armor.
The first thing I did was to paint the base tan color on the deck of my railroad flatcar. Later I'll try to make this look more like wood:
Next I decided to move forward on more of the Aerosans for the Treasure Train game that I'd been "threatening" to put on for a year now. I had one already half built so I assembled the engine and added it to the body to finish it up and have it ready for paint:
After that, I started the last one I have in my stash. I do need to buy a few more....
Anyway, I got that one half done before I realized I left all the engine parts at home. Still, it is started at least, and the engine will be easy to get finished and mounted on this. Here is the last one next to the finished on I just did:
Moving on from there, I next decided that the T-15 Armata was calling my name too loudly so I got started on that one. First thing I did was to build the turret. That went fast:
Next I added the detail parts to the upper hull. There wasn't too much to add, so this went fast as well:
After that I assembled the lower hull. I'm really thrilled at how well this model fits together:
Finally, I test fit everything together sans turret. This is one big beastie! Check this out:
I did stop there but I was having so much fun with this Zvezda kit that I pulled out the Terminator to finish up a bit more. The first thing I did was to assemble the rocket tubes and mount them on the turret:
They are pretty fiddly and will make turning that turret a bit hard. Moving on, I finished up adding the bogies and roadwheels to the lower hull:
I also added the side skirts and other detail parts to the upper hull as well:
Putting the upper and power hull together looks great, this vehicle is now ready for paint:
After that, I moved on to the final steps I needed to do to finish my Nagmachon. All the photo etch radar antennae, stowage fences, fenders and anti-RPG bar armor was installed:
After some touch up to the paint and adjustment to some of the photo-etch screens, I can declare this thing done. Pics of that are forthcoming later....
After that, I just wanted to build and/or paint. Since I wanted to move forward on some of my eight-wheeled trucks, I pulled them out and chose the AA-60 fire truck first.
While cleaning the seam on the end of the tank, I ended up cutting a big hole in the end of it!
Out came the sheet styrene and some squares were cut. The first one went on the holed end:
To make this look better, I added the other square to the opposite end:
I then trimmed the excess off with a pair of scissors:
...and some careful sanding later, I have a smooth finish on each end:
Next, because the end plates on the main body were not fashioned properly to fit without major gaps; I used more of that sheet styrene to plug the ends:
After some additional assembly, I then cemented the lower body and the forward engine cabin to the chassis. I then snapped the tank in for now. Here's how it looks so far:
Well, that was enough of fighting that. I then pulled out one of the KZKT truck cabs and started to assemble the interior:
Next I added the axles to the chassis:
Additional detail parts went on, such as the fuel tanks on the side. I also checked to be sure the wheels all line up and sit properly:
I then painted the interior of the cab:
Here's how the cab looks all assembled. I only snapped the outer cab on the interior:
Now that was for the KZKT Heavy Truck. I also worked on the MAZ heavy Truck, starting with the axles and fuel tanks on that chassis:
The MAZ has that split cab and so I assembled and painted the interiors for both sides:
And that is where I had to stop due to Hobby Day being over and all the work I've been doing this past week. Hopefully I'll have more to show soon.
Thanks all for looking in, comments are always welcome.
