Well folks,this one has come to an end.
But first I gotta tell you about some bad things that happened;
After I poored the Still Water on my diorama,I put it on top of a cupboard which wasn't flat.
I WAS convinced the water had cured....but....overnight some water oozed out of my dio.
And when I took it from the cupboard a little stream had gone from the pit the JP 38[t] was in out of my dio destroying some groundwork,ofcourse the water THEN allready was hardened... :vmad
So I peeled off some cured water with my knive....destroying MORE groundwork.
Had to do some groundwork and vegetation AGAIN!
Vallejo Still Water needs about 24 hours to cure 5mm of water...so they say.Well,in my case it WASN'T!
[Maybe it's because I mixed Vallejo paint in to it] :idonno
Here is was I peeled off;
Then there was the case of the winged BEAST,which with his beak had a go at the scattermaterial,think birdy thought it was birdfood...
Well,I can't stay mad at our parakeet KARELTJE. :laugh:
Ok,the final end pics...
Was thinking about a dead German soldier on the road,but decided to leave it.might be too much drama as in:https://www.modelersalliance.com/forum/fettes-figure-forum/86005-of-boy-and-horse
Closed the road with a rope,the white teared up cloth is teflontape,to make it more noticeable for drivers.Used signes,one of them is a warning for landmines.
That's about it!
I will post some pics in the completion section...just GOT TO have that cool looking Camo ribbon.
Greetings,Ron.
