Swordsman
Hello I'm very new Here ... but I've found some interest in this build ...
I ordered this Resin locomotive kit from Boulder Valley Models ......
Inside the instructions .... show what I'm building ..... I'll be using the Mechanism from a Athearn HO SW7
Here's a close-up of what I hope the finished build turns out like .... almost double in scale size HO to On3o narrow gauge Logging engine .....
The bottom innards We will keep the top innards ..... Back to some lucky buyer on eBay .....
I removed the trucks by removing top gear cover ....
Motor and trucks removed ready to paint the frame ....
I soaked it in white vinager 1st to remove the oils .....
Ok here the frame has been primed with MM grey primer .....
I painted the frame with Floquil engine black .....
Looking at the motor bottom you must remove these little copper fingers to insolate the motor from frame power ....
I also, Just for good measure glued a piece of styrene using Testors wood & metal green tube glue .....
I have added a wire on the bottom motor feeder .... it will be hooked to decoder ....
I Removed the side frames .... Too modern for this old Girl ......
I attracted wires from truck power pick-up for later use to hook up Decoder ..... I moved this wire from here down to the little brass brad .... I was having solder sticking trouble .....
Each side frame has 4 pieces .... they must be installed sitting on the track because of axle drop
The side frame is in four parts ..... this little holder for side frame .....
You must ..... clamp the truck to the rail so you can align .... the frames to the axle .....
Here's the finished side frame ..... with journal boxes ready for paint .....
Now we start on the locomotives bottom floor ......
This is a start .... the engine I featured in my introduction thread ..... This is a start .... the engine I featured in my introduction thread .....
Cheers !!!
Cheers !!!
