ausf
Besides humidity, the act of compression heats up the air. High humidity could be overwhelming the trap, but you could also be getting condensation in the hose after the trap.
Iwata makes a nice pistol grip trap, but you can also get one of those cheap traps for the base of the AB since you're only trying to cut down on the residual stuff.
I was plagued by what you're getting, I was using a sizable MT at the compressor, not an AB one, but the type you'd get from Home Depot. I added a cheapo ($3) trap at the base of the AB and problem was solved.
I eventually switched over to an Iwata SmartJet compressor that came with a nice trap/gauge and I haven't had an issue since. It may be Iwata uses a very narrow line post trap or that the trap is so efficient, but I haven't needed the added one at the brush.
Nothing is worse that doing a tight camo pattern and you get that water loogie out of nowhere.
That is basically the setup I have sans the MT at the airbrush. I ordered one so hopefully in a week or so, I'll have this licked. And yeah - My freehand camo job, took a bit of a beating from the sputtering. Fortunately I still need to add another color so I can hopefully get it cleaned up.
Once I bought the SJ, I haven't needed to use the AB side trap, but I also no longer spray when the humid. I keep a hygrometer in the shop since urethane resin is so moisture sensitive that I don't crack the containers when it's 60% or above.
I'm sure if you had to wait for under 60% in FLA, you'd have to find a new hobby, but I bet the pistol trap will solve it. It couldn't hurt to try shortening the Iwata hose before you went for the braided. They give you a ridiculously long hose with the SJ setup. I guess it makes sense if you're walking around painting details on a car or something, but as is with the compressor close it's more in the way than not.
