Thanks for the comments guys. Wow, so it's been a while since I worked on this. Got some stuff done tonight. I am taking this slow and steady as all the PE and resin is really difficult to cross reference with the kit instructions and I tend to go fast and screw up and miss things. If this is too much random stupid pictures just tell me. Anyhoo, I put this little screen thingy on the air intake. Looks cool from the outside but I doubt you'll be able to see it this way once it's all closed up unless I put a light behind it or something.
Then I closed up the nose. Seriously, what the hell Hasegawa? No locating pins? I didn't think you were a limited run company.... I put the air intake insert on and this other fun little fiddly bit in the rear here.
I also finally painted and mounted the ammo boxes for the MG. I used a lighter color just for some variation.
Lastly, I got the resin pods around the guns. At this point I am not impressed by the Aries resin for this kit. The fit is crap and the detail is only so so. I would suggest that unless you must have the doors on the cannon pods open you just buy the metal barrels and the Big Ed set and forget the resin all together. Most of the resin and the PE is redundant anyway.
Thanks for looking and being patient. I'm not a very fast builder lately. :java
