Re: Dad's motorgrader
You found a better image of the one I posted! You must be ready then.
I think they were in 1/48?
Well, crap!!!
I can't use the VLS bulldozer engine for the grader.
I just heard back from David Doyle, the author, who is known around the world for his books on soft skins. He authored a dozen or so for me through Letterman Publications.
He told me that The Cat motor Grader is powered by a 468-cubic inch Cat diesel 6-cylinder engine #12.
The VLS Dozer is a D-9. The smallest Cat dozer with a 6-cylinder Diesel engine was the D6, and it had a 650 cubic inch engine, hence clearly not the same. The D-9 was even larger. It makes sense, a dozer would have a much more powerful engine than a grader.![]()
The good news is that he not only has photographs aplenty, he has the manuals! :yipee :yipee
BTW, he said that to his knowledge, the only companies to supply heavy dozers and motor graders in WW II were Caterpillar, Galion and International Harvester.
Soooo, I'll just have to scratch the whole damned thing!
Bob
