1/350 Pre Dreadnought Tsesarevich.
Look good to me Tim, the railings on my Corvette are partially posts and rigging line. 0.3mm holes in the posts and 0.3mm line, makes threading a needle look easy :rotf
I haven't seen actual stantions with cable in 1/350 scale. I tried nipping off the bottom run on an extra piece I had just to see. It doesn't work well as the photo etch in this scale is to fragile.
It only took about 8 hrs to mask off the painted deck.
Very tidy, the time spent masking was well worth it. Its interesting for me because i do the opposite and paint each part as i go. I have noticed other people do what you are doing with cars and motorcycles but i never have. You have to be pretty sure of what you are doing especially in 1/;1 when i built and restored real motorcycles.
I always remember the cowboys on "American Chopper" who would get a frame or key part painted then drill holes in it to mount parts so under most screw heads was bare metal...still makes me cringe :) Test fits are essential before you paint.
These Trumpeter kits can't be trusted to paint on the sprues. Every tiny part has to be test fitted before painting. I like getting as much dry fitted as possible before paint and glue. I've never had any luck painting a deck then gluing it onto the hull Like I see a lot of modellers do.
All of the deck hardware is on. One of the things I've made for my build is the fore & aft flagstaffs. They can clearly be seen in period photos of the ship. Yet, they are not in the kit and I don't see them on other modeler's builds of it either.
Everything has a wet coat of Vallejo Varnish for the next steps.
The next step is paint the anti foul below the waterline.
Most all, in my research agree it was a greenish color when launched.
