1/350 USCG SPC-HWX 52-Foot Motor Lifeboat kit #126
@Rhino, about them tiny carbide drill bits, if you use them by hand (or with a pin vise), try the russian technique as witnessed in Ukraine, two twists forward and then retreat one. This cleans out the flutes minimizing the binding. I also lightly wipe my bits with lube (THAT doesn't sound right, does it?!) with a machine oil dampened paper towel.
I have a WowStick electric drill which I really like for its low speeds and high torque but the shank it accepts is too small for my carbide bits. I do have some ancient pin vises and went to Amazon (not Prime Day deals) to find this elusive 1/8th inch (3.2mm) collet. Found it but $6 for ten of the same item which fit my Dremel and Foredom but not my pin vises!
So, I considered the DSPIAE $30 glorified pin vise as recommended by @Heavens Eagle (whose tool suggestions I highly regard):
OK, OK, I will get to my point!
Then, I see this $10 item show up on my Amazon suggestions which is the pin vise, 10 assorted collets, and even ten carbide bits which I didn't have! 4.3 star rating and good reviews on videos... Ordered!
Duliwo 21 Piece Hand Drill Set, Pin Vise Hand Drill Set Including 10 PCS (1.6-2.5mm) Miniature Mini Drill Bits and 10 Brass Collets (0.5-3.2mm)
https://www.amazon.com/dp/B0D962LL1C
That's cool Paddy, thanks for sharing. Around here we celebrated Carolina Day, June 28 1777, Gen Charles Lee (future traitor) took credit for William Moultrie turning back the British (commanded by Sir Peter Parker (not that spidy one) and Henry Clinton) at Sullivans Island.
This is the battle where the ledgon of Sgt Jasper raising the SC flag over the palmetto logs was born of.
Sorry for the hijack Chris.
I did search and found this
A replica of a 15th Century ship which Christopher Columbus used on his first expedition across the Atlantic Ocean 500 years ago has docked in Eastbourne.
The 95ft (28.95m) Nao Santa Maria arrived at Sovereign Harbour on Thursday and the public will be able to tour around the ship until 28 June.
It was launched by the Nao Victoria Foundation in 2018 after 14 months of construction, and it weighs about 200 tonnes with rigging made up of 2.5 miles (4km) of rope.
"We prepare the ship for visitors to come and experience a flavour of this 15th Century ship, and discover more about the trip sailors did back in the day," said Alvaro Paniagua, one of the crew.
Paniagua said: "These sailors didn't know where they were going, they were trying to discover a new route to Asia. But they discovered a new continent.
"They really believed the world was ending and they'd find a giant waterfall."
The current crew live in the ship and are touring around the world. The next stop will be in Shoreham Port from 1 July until 12 July.
The construction of the ship involved nearly 100 professionals and combines fiberglass and wood. It also has engines but uses its sails in the open sea.
Navy veteran Ivan Jones, from Eastbourne, added: "It's so important they build these replicas so history can carry on and not be forgotten.
"To think they would cross the Atlantic, it's quite small."
@Sharkmouth
Saúl, My Dspiae Pin vice has a built in 0 to 1/8+ three jaw chuck built in. No searching for chucks or even changing them out. It isn't the thin skinny one you have pictured. It works perfectly and runs true no matter the size of the drill shank. I have a number of pin vices, Starret sizes A, B, C, D,(EXPENSIVE have them at work) Bergeron 5 sizes, one broke one day for no reason, (EVEN "MORE" EXPENSIVE THAN Starret and NOT as good).
My take on the DSPIAE that I have is that one beats all the others up to 1/8th diameter and is made better. It comes with a nice case, and some carbide bits for $20.
Here is the link:
Thanks @Heavens Eagle, so you have the second generation pin vise while the one I posted was the first but I would have expected you to have the third generation! ;)
While DSPIAE claims to have improved it, more stable collet grip and improved bearing on flared tip, they reverted to limiting the drills to one shank size! It is about $30 for the third generation AT-SHD with the tungsten steel drill bit set but I would definitely go with what you posted instead as I feel this is a step backwards.
However, I did get the Amazon special from Duliwo (VERY nice by the way) today and a back-ordered DSPIAE AT-ED as well.
@Rhino, this is your post so you might want to see my impressions in the Latest Acquisitions thread.
The third gen wasn't available when I ordered, and just looking at it, you are right it is a step backward. I have used mine with a #80 wire drill, and any number of 3/32 and 1/8th drills, Dremel cutters, and jewelers cutters (which are usually 3/32 shanks).
I can see plusses and minuses to this new tool. On the plus side, the actual drilling action will be improved, as your fingers won't slide down the bit with just a few rotations. This may work better than the bulkier (?) 3-jaw micro drill chucks I already have on hand. It sure is an eye-catching shade of red!
On the minus side, you've given yourself a longer "lever", if you will, that could lead to additional snap-age on the finest, most brittle carbide drill bits .04mm and smaller (the sizes I use the most) while drilling irregular shaped surfaces.
Any rolling off the bench may also cause breakage in practical model usage. That being said, not many teeny carbide drills survive any impact at all. My factory ones will roll silently in a leisurely circle before plunging to the floor or into my foot.
Every man must make up his own mind about his model space and his preferred set of tools.
The Mayflower quip was hilarious! I recognized the more bulbous design of a smaller, drab Spanish vessel. One might wish a ship-load of "migrants" may sail for their original homelands, rather than our shores, yes?
Somewhere on YouTube there is a video of the "Parade of Tall Ships Under Sail" and every one of them is motoring up a canal, rather than actually sailing before the wind. I pointed this out and had quite a "discussion" with the person that posted it. I insist that words mean something and proper verbiage is a must. Click-bait rubbish, in my view.
The blueprints don't lie. I got to looking at the bridge for the 1/350 SPC-HWX and the blueprints, and my part is inaccurate. The spray shields should have extended past the little ladders aft. Now they do. There's a new spotlight that doesn't obscure the helm, and an engine air intake grid too.
I found my 1/350 p/e portholes and those are superior to asking a buyer just drill holes for portholes in this scale. It looks a mess right now, but the castings will bear out the improved details in a single color, if the good Lord's willin' an' the crick don't rise........
The Boss around here is a stickler for accuracy and quality. He's kind of a prick like that. Imagine, a friggin' kit getting a revision before it ever hits the market! Some people's kids!
This is the end result of an entire day of TLAR micro model mania and a whole pot of good, hot coffee.
My Seester did come by with a present for my Sweethearts birthday and i got to see their new Jeep-4-door-car-thing. 1941 Willy's green, I'm told. I don't know about that. Roscoe wasn't around to ask about the appropriate color. No recoilless rifle,
Vickers .303 or .50 Cal MG's. City people don't know what belongs on a Jeep.
The 3 Little Molds are poured. I'll be rising early to demold and cast them all Monday around suppertime. Following that, the mold for the waterline 1/350 SPC-HWX can be built and poured. I will then catch up bridge structures for existing kits for both versions.
I hope this satisfies the expectations of my meticulous Boss!
I tried out my new hot knife on some stray counstruction insulation. I hve to say, I'm surprised how well this worked! Look forward to more "Ship-In-A-Cube" builds! Antelope, The Nancy schooner.
I picked up a cheap one at the hobby lobby and was tickled how well it worked. I haven't tested it yet on the base for the Carolina Lee yet. First things first.
Good luck on the production line. :popcorn
RTV mold rubber experiment failure. I opened this in December of 2026. The mixing of the RTV occured in the original package. A plastic jar, if you will. I had no expectation of contamination, but the label does say "Use as soon as possible", affirming my belief that the white silicone material is hygroscopic. That is to say, it absorbs water from the surrounding air, like brake fluid does. This material was bound for the trash, and still is, but some knowledge was gained.
I recovered all the Masters and am almost done cleaning and resetting the mold box. I will use the most recent RTV material I have to pour this mold a second time.
Conclusions: A clean, fresh mixing container is vital. Using the Moldmax-10 soonest is also important. Open containers last longer in dryer wintertime air. A smart man would prep a bunch of mold boxes and use an entire Moldmax container in a few sessions over a few days.
