Progress.
Do you need actual dimensions? As I wrote before, worry about the outer diameter as you can drill or ream to get the walls thinner. A projectile would obscure the view so you don't have to drill all the way through.I'm measuring the kit bazookas at 2.19 to 2.25 mm depending on location. I have a tube of 2.0mm that looks good but it's only enough for one bazooka.
I am not getting bare, as in naked, with you as you whip anything out! NAUGHTY!Bare with me while I whip this out.
