A6M5 Zero and Ki-61 Tony
centaur567
I decided to just do these two kits and to combine them into one thread to maeby simplify space.
The Zero is a Mitsubishi built airframe and in not sure as to the color difference of the Nakajima ones as far as the cockpit and camo.
On the Tony, the instructions say to paint it overall IJA Lt. gray with dark green blotches on upper surfaces unlike the box art. No natural metal. Gary S.
The Zero kit only came with a seated pilot that looked too much like a gringo. I had some left over parts from the A-36 kit which kinda works.
It's 0% accurate and will be a closed cockpit which hides a lot of detail, but at least it' better than nothing. Gary S.
Work on the Zero has progressed quit a bit. The wings and fuselage are assembled but not attached together. Along with the cockpit, they are just dry fitted together. So far the fit is pretty good for 1962 molds. Also the tail hook was just a small protrusion sticking out the bottom. I made one out of solder and cut out the opening for it. Now I need to make a tail light on the tip of the tail.
Work on the Tony is limited till there's time to paint the cockpit. The wings and drop tanks are glued together. My house to do list has grown a lot lately. Gary S.
Yesterday, Birthday Boy, got some time off for goog behavior, so he painted the base cockpit colors. This morning I did some of the detail painting with more to come later. Both canopies are closed and a lot of detail will not be seen. If the Zero didn't get some sort of cockpit, the wheels would be viable. Gary S.
Thanks for the Bday wish. As the years go by the aches multiply and feeling older intenseifies.What the hell happened?
The Tony cockpit is almost done, just needs a little touching up. Photo etch was used for the seatbelts and rudder pedals.
The Zero cockpit is done for what can be seen of it with that large Japanese pilot who still needs work done. At least the canopy fits. Sorta. Gary S.
The Tony fuselage is glued together along with the head rest assembly. Also, the wings of the Zero are attached. Fit on both are pretty good. Still working on painting the pilot. He's going to look like the guy on his right.
And I have a new hobby. Saw this beautiful orchids in Publix and just had to have it and it went on to the shelves that I just made. My other hobby, making stuff for the house. Gary S.
The Zero pilot is done, he still needs a joy stick.
The wings of the Tony are just dry fitted on. There's not a lot of dihedral. The fuselage still needs some body work. Also took a few pics of the cockpit. Gary S.
