centaur567
Time to get the Dremel tool out.
My plastic nuclear option is not fission but fusion and no Dremels, or any motor tools, required!Time to get the Dremel tool out.
Geess..sounds toxic!Out came the SCIGRIP Weld*On #4, a metal bowl, and tiny pieces of sprue runners cut along with shavings that happened while knocking down seam lines.
I'd advise against that as the plastic may get too soft and the mini-clamps leave a mark thereby giving you more work.I was thinking of using mini-clamps when dunking to help add pressure on the halves to get them to come together, we'll see.
Same technique as resin is a type of plastic.Roger that, I will mess with it till I get it figured out. You mentioned resin, these are plastic, unless I'm starting to lose it, which could be the case, lol.
In some cases, Liquid Polyurethane Plastic. Helmet water works better on my castings.Same technique as resin is a type of plastic.![]()
True @paddy, but we were discussing the technique of heating the parts to get them more pliable.Yea but there are many different types and resin like i am using on the MHF kits is Acetone proof where as Acetone will melt kit plastic with just the fumes. i expect the glues will be the same , i use a slow set CA
