Greg Kimsey
k,...so, I have been working on this model.
As you know, I like to open doors and trunks and what not and thought "Hey let's open the doors on Baby". I haven't documented the operation so far so I don't have process shots to show, but I am making this post now so I will catch you guys up on what I am doing with the car then show "where I am" photos tonight. First of all...the doors. This is a four door sedan, but the door post does NOT go to the roof. It is a free standing post a little shorter than the doors so it is hidden when they close. Like this...
How in the world does it seals to be waterproof and windproof I can't imagine, but I have found some really good reference photos of this yellow 4 door impala and am using them to add the details. I still have to figure out how to hinge the rear doors. I have made posts by gluing three layers of 2mm styrene sheet and shaping. I have the inner door panels in place and spacers made with styrene and putty to get the right depth. I lay the matching doors on a cloth and put Tamiya tape over the space between to mark the shape of the pillars front to back, then used card stock to make a template to match the arc shape for the door convex shape. Filling the space between the back seat and fender has not come to me yet.
I did open the trunk and used styrene to make the inner bracing on the underside of the lid. I am also using plastic card to line the trunk. There are some some gaps that I can't figure out, so my solution will be to use fabric to line the trunk and cover any openings that remain. I used flat copper strip to make the hinges so that they sort of resemble the real thing.
I opened the glove compartment and I intend to 3D print a pistol to go in there. I boxed out the compartment with 1mm plastic card and made a new door with thin copper plate to replace the thick plastic molded door; now to figure out how to hinge it so the door opens and stays flat.
The hood will have working hinge if all goes to plan. I have ordered tiny springs to see if I can make a miniature working realistic hinge like what is on the real car. Never done it before but I have seen it done.
The seats will hinge, blah blah blah, nothing new here. None of this may work out but I am givin'er the old college try. I wasn't going to document in case of an epic fail because I am not really sure I will be able to do this, but was persuaded. Stay tuned for updated progress photos of the actual real life model!
Oh, I see this now. Ok. I'm calm again now.
