jknaus
Administrator
As I finish up the SA-5 I decided to do the new Miniart Type B Lorry. First because its so cool and secondly so I can see trouble areas before I do the bus. Well the engine is almost done.Goes together so well. The have PE spark plug connections but the distributor just has some small pegs to glue the wire to. So I drilled them out and used .6mm albion tube. Hopefully I can get some pics later on when I go to do some more fiddly stuff on the SA-5.
