1/48 Eduard kit. I added ignition wires to the engine (see if you can find them) and replaced the molded on instrument bezels with photo etched ones. I also used an aftermarket seat and replaced the molded on throttle assembly with photoetch. I took some criticism of my simulated wood grain at the local model club meeting (one guy said,"maybe it won't look too bad after you close the fuselage") However, I am of the opinion that aircraft grade plywood does not show much grain and the distinct striations seen on a lot of models would not be realistic in the smaller scales. Opinions? The kit has the traditional tongue und groove wing to fuselage attachment, but the tongues and grooves are ridiculously shallow. I sensed a likely fail and inserted some steel pins for reinforcement. In addition the landing gear struts were butt joins so i drilled out the ends and added steel wire reinforcements. Sorry for the sub par photos. Model builder I is, picture taker I ain't
https://i297.photobucket.com/albums/mm236/rlhart13/DSC04204_z
