Think I'd rather do a Lee myself, Sherman name still shakes up thing down around these parts...
Looks great Jeff![]()
So a Grant is out too :tomato
I think I went one coat to much on the hull and lost some of my pre-shading, but I still have some camo to put on it so maybe I can play with it. I'm off to the store to get some silly putty :geek
Even pulled off some of the casting numbers I added :vmad
Wow! Pulled up Tamiya? What was the base, Tamiya white? Try this, scrub off the silly putty residue, do your repairs and touch up the paint then seal it with an Acrylic Gloss and let that cure before masking again. Then do the camo again. I'm thinking the silly putty would stick less to the gloss surface as it would a flat one.
What are you using to thin your oil paint? Never had trouble with oil wash effecting Tamiya acrylic paint.
Alclad II Aqua Clear, Future (get that at Lowes and sprays out of the bottle), Model Masters Acrylic Gloss and they have a Flat/semiflat. I've been playing with the art supply brand Liquitex varnish. Last night I tested it's Matt Varnish on some old builds, it worked well so I flat coated the IL2 with it. I'm sure their Gloss varnish will work. Got that at Hobby Lobby.
Sending :zen
I put it on heavy too. Going to let it cure for 24 hours or so then hit it with Testors lacquer flat and see what happens.
Oh, another thing I started using on the paint job is I have changed on how I clean the airbrush. I saw something for a guys who airbrushes for a living and he uses carb cleaner in a spray can after each color and or use. It was said that it cleans and lubes the airbrush without taking it apart. So I got myself a can to try. Might have helped me or made it worse, but my airbrush is clean![]()
But you know, I think if you rinse it with some Windex maybe, it'll clear out any residue. Just a thought.
