phantom II
Does anyone have any idea how to replicate the look of this cowl ring without a long process ?
Any thoughts welcomed.
	I assume you mean the corrugated look. I dont know how well it would work, but maybe wind fine thread around it tightly as if winding an armature. Then when the whole thing is wound apply cyano glue to the outside only. Then when dry trim the thread front and back so only the outer surface has the corrugations. Then add a ring on front from plastic or glue or something then paint. I think that would work.
 I'd buy it.The foil that pops out of the front of cigarette packs, it has a similar texture. don't have any I could send ya a few. CR
I'll have to try and find a smoker and check that out. Haven't looked at a cigarette pack since 1985 myself. Sounds like I'm missing out on something
Thanks, Christian
Hmmm...that's a tough one. :hmmm
How about laying a piece of Tamiya tape on a clean glass surface and cutting it into
thin strips. Then peel them off and apply to the cowl. After that I would paint on
some Mr. Surfacer and stipple it a little to get the rough texture.
The front ring will be tough too. Could try some flat lead wire, form around the cowl
and CA in place.
Tom
There is 1/64" (0.015") wide pin stiping tape out there.
Might still even be too wide, but anything narrower might be
impossible to work with.
Tom
I would use a thin layer of epoxy putty indented with a blade, getting a small section exactly how you want it. After it sets, make a silicone texture stamp from that and do the rest.
Micheals sells a kit that is a two part food grade silicone (it's purple, like $15 before the 40% coupon) that sets in a few minutes. I use the stuff all the time for quick replications as opposed to pulling out the scale and vacuum chamber for a proper cast. The stuff is amazing, the two little tubs last for a long time.
You could cast the cowl and make chocolate replicas afterwards.![]()
I hope you do get it right I myself have no idea how and All I can add is that I am very glad I quit smoking in June :woohoo:
