Pz.Kpfw.III Ausf M mit 3.7cm Flak 43
jknaus
Administrator
Okay to recover from Fokker burn out and while I wait for a new engine I will scratch the armour itch with a Pz.Kpfw.III Ausf M mit 3.7cm Flak 43
This is an almost maybe what if. No one knows if any were produced that I can find. It was created to protect the Stug Abtelungs by mating the Ostwind turret with a Stug III or PzIII.
Here is where I am so far.
Some minor things so far. In the muffler instruction 2 part numbers are transposed. A9 and A10.
Another thing I found was there is no clear locator for part a7. I glued mine in place and found it caused fit problems. I could remove it though as the glue wasn't fully set. I recommend letting it float until the exhaust and rear panel are mated then gluing it in place.
Also when you put the aft section on there are a bunch of stubs on the chassis. The aft section doesn't fit with them on. They even have them in the instructions. I removed mine and they fit better.
Comments welcome.
:popcorn Nice little tank you found there James,
I'm still amazed that they can't make an instruction that's correct :idonno don't they testbuild the kits after the instructions?
Not just Cyberhobby, Dragon and Miniart and Bronco are good at that to, Nice kits but then they put together a mediocre instruction :stinker
I will follow along and see how it turns out :drinks
//Mats
Attaboy James always good to see more armor. (y)
Oh and by the way he could shoot a fokker with it. :lol:
Terry B)
Okay got some bench time this morning.
I see I didnt pay enough attention to the doors, will need to fix that.
Almost ready to start painting the chassis. Have a gun and trac k coming also.
