As usual i don't really have a clue what i am doing here but this is my inspiration...
Its a fine example of why its best not to use old pictures for colour (apart from it being Black and white) :laugh: as we can see here as i do a little more research
This is a Spit MkXVI (16) its number is RW396..i checked RW996 and it wasnt built..
this Spit has an entry in my copy of "Spitfire the History" (Shacklady and Morgan) and states the following:
RW396 XVIE CBAF (stands for Castle Bromwich "Built" Aero Factory), Assigned to 29MU (No. 29 Maintenance Unit) 24-7-45
CGS (Central Gunnery School) 2-4-46
eng fail cd f/lndg West Skipsea Ranges 6-1-49
cd = category D which is insurance speak for write off.
So basically it was built mid 1945 and assigned to a Maintenance unit. not unusual while it was waiting to go to a Sqn. She then spent all here life life with the Central Gunnery School until she crashed due to engine failure on the 6th Jan 1949. at West skipsea
This was a coastal range which edged the North sea, the airfield used was nearby RAF Catfoss. this might explain the worn and rugged look as these aircraft would have flown up and down this section of the North Sea coast which would be pretty bleak in winter.
This picture is unusual as the markings seem a bit odd as it has a yellow outer ring to the fuselage roundel which i guess is still there from its war days at the MU and the wing roundels have a white ring and are full size...
My model will be halfway between this aircraft and the kit aircraft decal wise so a bit of a what if but then there were not ant really hard and fast rules with markings regaurding war built aircraft that served on post war it seems.
My model has a coat of white
then a coat of silver
Next it will get its decals while its still shiny then a flat coat to turn the silver into a whitish Grey. followed by a ton of weathering. (can you tell I'm making this up as i go along
I tried this out with normal silver and it didn't really work so i bought some of Tamiya's alclad copy paint but didn't use the black base...ie i used a white base and it seems to work better as the alclad type paint is not as metallic and gives more of a chalky weathered aluminium/silver dope type finish with a flat coat applied..
M<ore soon if i can find some decals !!
