phantom II
Ha ! Just read the last line on the hardener " Depends on moisture ". It just rained :vmad
I will try to BS. my way through it when I shoot some paint. :fencing
B)
Good evening ladies and gents . Having received a replacement kit from Aires where all the kit parts fit together got this kit back on track.
I got my highly technical jig out so as to get everything lined up and square , so here we go.
The wings are on and any gaps were sealed. Believe me, the wing installation was not a piece of cake. Things had to be trimmed and forced into place.
All in all, I got it to an acceptable fit. The only trouble spot left is where the lower trailing edge of the wing meet the rear fuselage. The ribbing in the material do not have an equal spacing.
The replacement flight control still had to be carefully to fit together. After I shot primmer I discovered the the leading edges of the balance horns were blunt instead of tapered. So, some sanpaper adjustments took place.
I drilled some hole and installed some torque tubes . Voilas, they are ready to instal.
Comments are still welcome . Hope to get it primed tomorrow. Cheers, Christian B)
