going back to the Austrian one...nicknamed it Arnold Dustynegger.
More dust effects with pigments and pigment washes (pigments with enamel thinners)
Driving your car through mud don't clean it and then hot weather kicks in,you will get rock hard clumps of dryed mud,hard to remove.
Use several layers of different colored pigments to show different kinds of moistend mud or dust,it might be dry but there is still some moistness in the mud and dust.You could use just one color of pigment that's right,but multi colors make it a bit more interesting.
Pigment washes on the tires.Once it is dry the color will go back from a dark color to it's original color,and you can wipe away the overdone part using a stiff brush or even a finger.IF you use enamel thinners in the wash that is.
The white stuff you see is Patafix that I used to temporary hold the doors while airbrushing,the doors will be opened later on.
Arnold Dustynegger got a rudely,fastly done Dark Yellow camo striping over it's Panzer Grey body;typical for the year 1943 when Dark Yellow became the base coat of Wehrmacht vehicles and there was not enough paint for all of the vehicles.Probably if the car would live to see the day,it would get a full coat of Dark Yellow with or without camo colors (green and or brown).
Managed to break off some how the 'driver knows rod' left of the head light,will fix it later on.Also managed to break off the mirror btw.
Still got a lot of work to do on it;detail painting,markings,washes,chipping and so on...and adding more dust.
Thanks for dropping by,more to come later.
Greetings,Ron.
