Thanks guys!
Another quick little update tonight! I'm ready for some more paint finally!
Had to fix up the pitot tube. All I did here was cut the small end off, and cut a small piece off the end of a needle. Then I drilled out the kit piece and glued the needle in. I then added a small piece of sprue for the triangle thingy on top!
I also got the port engine and nacelle fixed up and mounted.
You can see one of the spots on the aft fuse I need to touch up.
next step is some more painting!
