Logistics, Base & Buildings, Updated Jan. 5, 2020
Got some more details to post. They are built, painted, and all need some weathering, or, in this case, aging.
Some of the benches and seating in the grand hall.
The wood grain applied and the cushions painted.
The hole made by the tank round. (Base coat)
The same almost finished.
The sign for the snack shop (Base coated)
The train station sausage snack shop. (Imbiss in German).
The menu for the snack shop.
Together, partially tucked under the staircase.
A telephone booth w/pay telephone.
Two photos of the side wall of the Grand hall.
This is a portion of the roof section. The areas with the tiny frames will be glass and the remainder will be standard roofing. It also has lighting for the Grand Hall. The remainder of the roof cannot be completed until the building walls are assembled an permanently in place. The entire roof will be 18 inches, (457mm) in length. Then will attach to the train shed, (Where the passengers board), that will be 6 feet, (30.48 Centimeters) in length. The shed will be partially collapsed onto the K-5 Rail gun in the center portion.
The following two photos are different angles of the support columns for the roof that will be in the Grand hall.
Thanks for looking in!
Bob
