EJ youre making this look waaaaaaay to easyLittle wood flattie update.
The hull and superstructure done and painted. Looks pretty good I think.
The sticks for the mast, boom and gaff.
The sticks - tapered, drilled for rigging, stained and varnished.
Some do da's pre-assembled and stained and varnished.
Trim pieces and toe rails, Samson post, rudder ( I made the tiller out of walnut for looks), centerboard, companionway door and hatch, coaming trim.
Will put a coat of clear gloss on this stuff tomorrow, the, ready to trim this little baby out. So far, I havn't even broken a stick.
EJ
EJ![]()
Rub-a-dub-dub time to put it in the tubThat's nice! Would this be water tight? Not advocating playing in the bathtub with it just wondering...![]()
I believe it is. Probably need some ballast, but I'm positive it would float.
:yipee
EJ
:yipee
EJ
Looks good, put a coil of line or something over that spot, if it were a tank you could do a tarp. :solider Don't let something like that spoil a great build.![]()
Not quite as bad as being washed down by a parted black oil line during UNREP, right ED?
