Model Maniac
Member
Apart from military models, I've recently developed interest in laser pointers and
I've acquired the following during the past few months:
- 1 x 5mW 532nm Green Beam Light Laser Pointer
- 1 x 5mW 650nm Open-End Red Laser Pointer
- 1 x 1mW 532nm Green Beam Light Laser Pointer
- 1 x 500mW 532nm Green Beam Light Laser Pointer w/ Kaleidoscope Head (Shaking type)
- 1 x 50mW 405nm Violet Laser Pointer
- 1 x 5mW 532nm Green Beam Light Laser Pointer (another one)
- 1 x 500mW 532nm Green Beam Light Laser Pointer w/ Kaleidoscope Head (Rotating type)
(In USA, the law allows possession of not over 5mW Laser Pointer, in UK & Australia not over 1 mW)
And a few days ago I got another one which is the most powerful laser pointer available commercially.
It's a 3W (3000mW) Blue Laser Torch, as seen in the following iamges, compared with 500mW Green Laser:
While 500mW Green Laser Pointer uses 1.5V AAA x2 batteries, the 3W Blue Laser uses 3.7V Lithium
(#16340) x2 batteries. The set comes with 2 batteries, a charger and 5 Kaleidoscope heads.
Holes poked on plastic sheet and thick black plastic bag by the 3W Blue Laser. It can light a match
and explode balloon with ease:
Size comparison with 500mW Green Laser:
Watt comparison:
Pointed to the night sky at 60 degree. Only blue ray was visible through the camera lens:
Pointed horizontally with flash on, only blue ray was visible while the green laser showed only end-point:
Pointed horizontally with flash off, green ray is faintly visible at the left side of the blue ray:
Not because 500mW Green Laser is not powerful, it's just can't compare with the 3W Blue Laser!
Watt comparison:
