Paulw
I am getting to be like T and produce kits at an alarming rate....for me at least.
I started this today and I have some issues and some kudos for this kit. First is the good stuff. This one fits like a glove.
both sides fit this tight at the wing root and no steps or gaps so far.
I really like this subject and have been wanting to build one of these for quite a while. but it does have its flaws.
One is the pit is really lacking in detail so Paul Fisher has the solution with the pit kit that I receiver this week in the mail. According to Fished the kit canopy which is a one piece affair needs replacing. OK I'll agree and the pit opening is too small so there is a fix for that.
You have to saw some of the kit away to allow the wind screen to be correct However the instructions to do this is lacking some info as to EXACTLY where you are supposed to cut. This is what I got after following the instructions as best I could.
So I fixed some for sale sign plastic to shim it a bit and then Ill have to do some filling and sanding.
But it looks not too bad so some filling may just do the trick.
Also the wings need some serious detail also, I was going for the wing fold kit but I had to buy an air conditioner this week so that did that in. However, the wheel well is rather deep going aft anf the whole thing cries scratch build.
The only other thing that is rather sad is the real thick panel lines but I can either over come it with some filling(the whole model?) or just ignore it. Easy is best.
More to come later.
![IMG_1219.jpg](http://i1237.photobucket.com/albums/ff479/Paul6187/IMG_1219.jpg)
![IMG_1209.jpg](http://i1237.photobucket.com/albums/ff479/Paul6187/IMG_1209.jpg)
![IMG_1211.jpg](http://i1237.photobucket.com/albums/ff479/Paul6187/IMG_1211.jpg)
![IMG_1214.jpg](http://i1237.photobucket.com/albums/ff479/Paul6187/IMG_1214.jpg)
![IMG_1215.jpg](http://i1237.photobucket.com/albums/ff479/Paul6187/IMG_1215.jpg)
![IMG_1220.jpg](http://i1237.photobucket.com/albums/ff479/Paul6187/IMG_1220.jpg)
![IMG_1221.jpg](http://i1237.photobucket.com/albums/ff479/Paul6187/IMG_1221.jpg)
More to come later.
